Fan stays on Forever
Old Aug 22, 2003 | 01:06 AM
jeems's Avatar
jeems
i be slow
Default Fan stays on Forever
My friend just bought a 91 Accord and the fan will stay on for like 3-5 minutes after the car shuts off. Is this normal or what?
Old Aug 22, 2003 | 05:04 AM
hype8912's Avatar
hype8912
Dr. Klaw
I don't know if the 90 and 91's have the delayed cooling fan. The 3g accords have the delayed cooling fan that ran for a few minutes after the car was shut off. From the looks of the manual, there is a fan timer control which is why the its running after. Maybe some other 90 model 4ger's can post in here.
Old Aug 22, 2003 | 07:31 AM
Prince's Avatar
Prince
could be thermostat going or something too
Old Aug 22, 2003 | 12:31 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
nope my buddies 5th gen accord, the fan would stay on for 1-3 mins after the car is shut off. I wish my 6th gen would do that i would think it will be good for the engine to cool off.
Old Aug 22, 2003 | 12:32 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Normal but you may want to check the temp control unit to be sure.
My 4th gen LX wagon does the same so I think its pretty normal. Now if it stayed on for 5 - 10 minutes then there is an issue.
Old Aug 22, 2003 | 01:05 PM
Samson's Avatar
Samson
chris is the devil
it is normal for the fans to come on and off after you have turned the car off... it says in the owners manual it can do this for up to 15mins after the ignition is off.... my car does not do this unless im driving like a maniac.... and/or i take my heatshield off causing more heat in the engine bay.... but anyway... if u read your manual, it says its normal up to 15mins.
Old Aug 22, 2003 | 01:07 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Also he is in Texas where its hot like a mofo so it should be on for a while after shut down.
Old Aug 22, 2003 | 01:11 PM
A_D's Avatar
A_D
Reset?
my 97 does this too
i'll shut off my car and for about 1-4 minutes the fan will stay on
it does this every time i shut the car off
unless i don't give it a chance to warm up and then shut it off i think. i haven't really paid attention in that scenario
Old Aug 22, 2003 | 03:06 PM
hype8912's Avatar
hype8912
Dr. Klaw
You may want to check you coolant for the right mix and amount. It may be running hotter since the coolant level has broke down or not enough in it. Making the vehicle run hotter.
Old Aug 22, 2003 | 06:31 PM
cac's Avatar
cac
My 91 ex accord did this 1 or 2 times and i thought something was wrong because it never does this but I don't know why?
