Brakes...would this work?
Old Aug 21, 2003 | 09:29 PM
aero3685's Avatar
aero3685
Default Brakes...would this work?
Im trying to figure out what to do about my brake setup as everything needs replacing. Its on a 91 accord lx. I was thinking about accord wagon calipers and mounts, prelude si vtec92-95 rotors. I want to also get this to rotor over hub. Will the 99 cl 2.3 bearings and hub assy attach to the preludes rotor? Or could i just use the lude hub/bearing assy, without changing anything else.
I know the first part(calipers and rotor) will work, Im just trying to figure out what parts to make the rotor over hub work.
Also, what size bolts am I going to need to attach the bearing/hub to the rest of the hub, and the hub to the rotor, and then the lug bolts.
Thanks for any help, I initially was just going to do the cl 2.3 rotors, hub upgrade, but i need calipers now also, so figured why go back stock.
If you have any comments/suggestions, please respond asap, cuz im gonna try the junkyards tomorrow morning.
thanks
Old Aug 22, 2003 | 01:12 AM
TypeSH's Avatar
TypeSH
yes, but the screw holes may not line up.
you may use 98-99 2.3 or 3.0 CL rotors and the screw holes will line up..
if you use 2.3 rotors or prelude S/Si (think Si's had 10" rotors), then you can reuse the stock caliper. if you use prelude VTEC or 3.0 CL rotors, u need a bigger caliper.
you press the hub to the bearing either w/ a big f'ing hammer or a press.
the hub should have 4 studs already, rotor goes on and 2 screws hold rotor to hub.
Old Aug 22, 2003 | 07:57 AM
aero3685's Avatar
aero3685
Well, I have to get new calipers anyways, so i figured why not upgrade... so i could use
93 wagon calipers
3.0 cl rotors
2.3 cl hub and bearing
and all that will line up giving me a bigger caliper/rotors and rotor over hub right? Guess I can always get the parts, and if they dont line up.. return them. Cuz I have the 2.3 cl's rotor, and bearing and half of the hub, but i think i will return the 2.3 for the 3.0
Thanks
Old Aug 22, 2003 | 01:40 PM
TypeSH's Avatar
TypeSH
i have those on, except i have 3.0 CL calipers instead of wagon ones. The accord and CL bearings should be the same, either interchangeable, get whatever is cheaper.
Old Aug 22, 2003 | 03:19 PM
chamm25's Avatar
chamm25
Do you really care?
check out this thread from accordingly done
http://www.accordinglydone.com/forum...?threadid=1177
Old Aug 22, 2003 | 03:37 PM
aero3685's Avatar
aero3685
last question... can i use the cl 2.3 bearing also? Thats what i have right now, but i wanna make sure. Or should I get new ones for my car
Old Aug 22, 2003 | 03:56 PM
TypeSH's Avatar
TypeSH
yea thats me posting at AD too. yea you can use them. I'm not sure if honda actually made the part any different, but if u goto the autostore, they sell u the same part number for either car. I just went w/ the one that was cheaper when I was shopping, the accord one
Old Aug 22, 2003 | 04:09 PM
aero3685's Avatar
aero3685
yeah, i just compared the #'s and they match
so im gonna get the rest of the hub from acura, and some new calipers and pads, and i should be set.
I read about a good brake fluid, cant remember the name... anyone know what it is?
