'91 Accord EX Power Window Problem
Old Aug 20, 2003 | 08:27 AM
cac's Avatar
cac
Default '91 Accord EX Power Window Problem
Beginning of problem: Drivers side window went down half way and stopped, works o.k. now.
Passenger side did same thing, worked o.k. for a few days and now does not work at all.
Fuse is good, windows are clean, weather stripping is clean.
I'm thinking the relay.
Anyone know how to test it, or have this problem and have any suggestions?
Old Aug 20, 2003 | 10:10 AM
sickhonda's Avatar
sickhonda
If the driver side window is working perfectly now and the passenger side doesn’t, then we can definitely rule out the fuse or the relay as the source of your problem. They share one fuse or relay, if any of them goes bad, then all windows will be affected. Do you still hear a motor running, like clicking sound, each time you raise a window? Sounds that your window regulator motor is slowly going bad or already did. The window regulator motor is the mechanism responsible for raising and lowering the window and with your car year, it’s common for them to go bad…on some cars even sooner.
Old Aug 22, 2003 | 11:07 AM
hype8912's Avatar
hype8912
Dr. Klaw
Its most likely the window regulator. I've seen them on e-bay for like 55 bucks each with a 1 year warranty.
Old Aug 22, 2003 | 06:34 PM
cac's Avatar
cac
I don't get any sound when I depress the switch, no clicking, nothing.
Old Aug 22, 2003 | 07:48 PM
93accord4door's Avatar
93accord4door
upgraded to 97 ;]
i had the same problem, bought a new motor and tunred out to be the switch not saying that is ur problem but dont rule it out
Old Aug 23, 2003 | 09:10 AM
Accord96's Avatar
Accord96
Lurker
I had the same problem as you did in my 96 accord, with the same story as 93accord4door; problem being the master switch. You can get these at junk yards for cheap (bought mine for $25) and it works perfect now.
Old Aug 26, 2003 | 04:03 AM
cac's Avatar
cac
Took apart the door.
There is a connection that leads to the motor (a small, grey connection), tested and got voltage when switch was turned on so I think the switch is ok.
I think it's the motor, anyone know how to get the bolt off the front side of the passenger window, it won't drop to an opening (that hole they show in the manual) in the door to get a tool through to unbolt it.
What ya think about the price for a motor?
Old Aug 26, 2003 | 05:19 AM
REbornHONDAneer's Avatar
REbornHONDAneer
Honda Biased
When i had my 96 lx sedan, my drivers' side went out(regulator that is). DONT take it too a dealer, i spent over 300 bucks gettin it fixed. This was when i just bought the car and i didnt know much about "DIY". The part was $100 and the labor was $200. So you shouldnt be paying any more than $100 for that part. Like other people have said, you might pay alot less. Just shop around.
Dave
