?HELP?Sqeeking Click Clack Sounds?HELP?
Old Aug 13, 2003 | 07:35 PM
NightRider79's Avatar
NightRider79
Default ?HELP?Sqeeking Click Clack Sounds?HELP?
Oh man!! these noises are driving me up the wall.
1st. When I drive I hear this squeeking sound from my front driver side tire....
Anyone know what would be making that noise (ball-joint)?
2nd. Then when I brake I hear a clicking sound coming from my passanger side front tire.
Anyone know about that one ( brake pads need changing) ?
3rd. When I turn left or right steering feels chunky and I hear clicking.... that would be my axel telling me to change it or control arm?
Old Aug 14, 2003 | 09:04 AM
JimBlake's Avatar
JimBlake
#1 could be worn brake pads rubbing on thier warning tabs.
#3 could be the steering rack or tie-rod ends.
All of 'em could be different things. Gotta inspect parts & we can't do that from here. You have to take off the wheel & look at the suspension to tell the difference.
Old Aug 17, 2003 | 09:06 AM
NightRider79
Thanks for the info
Old Aug 17, 2003 | 06:54 PM
Mr Hyde's Avatar
Mr Hyde
Accord Forum Moderator
Clicking from the from the front end, especially while turning is classic for worn out CV joints
Just call me.............Mr Hyde
03 Topaz Blue 540i M-Sport
The TL-S / The 540i
Old Aug 17, 2003 | 11:46 PM
PUSHIT's Avatar
PUSHIT
jack up your car and see if the ball joint look like this
if it isn't sitting flush like it should, then get that control arm replaced asap unless you want your wheel to fall off or get locked up at a 100 degree angle while driving.
otherwise, my guess is the cv boot
Old Aug 18, 2003 | 03:20 AM
Bl@ck's Avatar
Bl@ck
Sinner
joint... the CV joint.... the boot is just a piece of rubber that covers the joint and holds the grease in.
Old Aug 18, 2003 | 10:23 AM
NightRider79
Thanks again for all the info guys...
I dropped my ride off at the mechanic shop earlier today.
I found out both my axels were broken, everything else seems ight, even though i haven't driven it yet...
hope thats all the work i need done ...
I also went ahead and replaced stock rotors and pads with
EBC Green Stuff & EBC Slotted & Drilled Rotors
