idle problem
Old Aug 6, 2003 | 02:35 PM
jlegendr's Avatar
jlegendr
Default idle problem
My 97 Accord is idling funny after the car warms up. When I come to a stop at a red light, the idle will drop down to about 100/200 RPMs and the car feels like it is going to stall but has not stalled yet. It stays there for a second or two and then goes up to about 400/500 RPMs and does this cycle a few times before leveling off around 500 RPMs. Sometimes it never levels off and will continue to drop and rise the whole time I am idling. The a/c makes it worse. If the a/c is not on, it still does this but not nearly as often. If the a/c is on, it happens at every stop. I have already tried a tune up. (Plugs, wires, distributor, rotor, PCV, air filter). I also changed my oxygen sensor because my check engine light was on. Since I replaced the oxygen sensor, the check engine is no longer on. Any advice.
Old Aug 7, 2003 | 09:35 AM
head's Avatar
head
take it to the shop
it could be a number of sensors
Head
Old Aug 7, 2003 | 02:52 PM
jfiedler's Avatar
jfiedler
Junior Member w/Fries
maybe map sensor...defective iac valve...if you have an automatic...could be a failing torque convertor.
the first two won't always cause the MIL to come on. the torque converter almost always will throw a VSS related code.
Old Aug 11, 2003 | 07:44 AM
jlegendr's Avatar
jlegendr
I checked the MAP sensor and it is functioning as the Haynes book says it should. I also checked the IAC valve and it has the right resistance. Those two seem to be fine.
Old Aug 11, 2003 | 08:45 AM
LudeBehavior's Avatar
LudeBehavior
Could be a bad fuel pressure regulator. disconnect the vacuum line from your fuel pressure regulator, and then drive it around for a while. If it doesn't stall or drop rpm's, then that could possibly be your problem.
