Tire Pressure Help
Old Jul 11, 2002 | 01:26 PM
MoreSlowthango's Avatar
MoreSlowthango
Default Tire Pressure Help
Need help on what tire pressure to use with
Nitto 450 215/45/17.
And Post whores.. I did a search. So only post if you can help!
'tanks!
BC
Old Jul 11, 2002 | 02:14 PM
GotBoost?'s Avatar
GotBoost?
Old Jul 11, 2002 | 02:21 PM
PmPiNAzNBoI's Avatar
PmPiNAzNBoI
WaSsuP?
Default Re: Tire Pressure Help
'tanks!
BC
Go read the sidewall of your tire. There's a BUNCH of information on there.
Old Jul 11, 2002 | 03:49 PM
JJJ784's Avatar
JJJ784
No Soup For You!
low pros are around 44psi, i put mine around 40-41. "normal" tires don't require such a high pressue, but if you do, you'll get inside wear on your tires. low pros need to be higher psi because of the profile, and if not, sidewall will crack on the inside.
Old Jul 11, 2002 | 04:52 PM
smakdown's Avatar
smakdown
I use 32 psi in my stock 185x70x14 tires. Does this sound about right for stock tires?
Old Jul 11, 2002 | 05:23 PM
JJJ784's Avatar
JJJ784
No Soup For You!
smakdown. sounds okay to me. max would be around 36 for stock tires. i have my stockies around 34.
chimchim
Oct 30, 2005 06:16 PM
