grinding going into second gear
Old Jul 28, 2003 | 07:06 AM
br2819's Avatar
br2819
Default grinding going into second gear
i noticed the other day that when i shift into second accelerating hard there is a grind when i try to put it into second. the clutch is all the way down so i don't know what it is.
Old Jul 28, 2003 | 07:25 AM
AccordSleeper's Avatar
AccordSleeper
Former H22 Accord Owner
synchros....change your tranny fluid.
use honda mtl, if that doesn't work try redline mtl, if that doesn't work than gm synchromesh
Old Jul 28, 2003 | 04:22 PM
br2819's Avatar
br2819
it only has like 6000 miles on it.
Old Jul 28, 2003 | 04:26 PM
jfiedler's Avatar
jfiedler
Junior Member w/Fries
start double clutching. :thumbup:
go to the dealer...usually they'll cover it under warranty, even though it's almost always caused by driver error.
couple exceptions to driver error are the 5th gen accord 5th gear grinding problem, and the 98-00 civic 3rd gear grinding problem.
Old Aug 6, 2003 | 12:50 AM
RY2K's Avatar
RY2K
5 speed
are you yanking it into 2nd gear?
try, after you push the clutch down pulling it out of 1st and waiting a little bit longer than you would normally change and see if it goes in nicer
