blue led dash conversion **help**
Old Jul 27, 2003 | 04:28 PM
pinoybboy's Avatar
pinoybboy
Default blue led dash conversion **help**
Alright so, i've already completed the mod...but i made a mistake on two of the lights (considering this is my first time doing it, lol it's not THAT bad =^_^=). The two lights don't light up due to a soldering error. I was soldering the led's onto the pcb board and apparently i scraped off the metalic lead ON the pcb board. I'm just curious if anyone knows how to ....fix this. LoL i know it's a stupid mistake..but hey, it was my first time and ish...it's so hot in my room..i couldn't concentrate =(. N eeeee how, thanks a lot.
Old Jul 27, 2003 | 04:29 PM
Rawbeef's Avatar
Rawbeef
chillin
pic??
Old Jul 27, 2003 | 04:35 PM
AcsRcool's Avatar
AcsRcool
Faster than your Geo
**** man, thats tough, there was a kid in my class who did that to a design project (electrical engineering)
you'll have to connect the scratched lead and the LED somehow, i think he soldered a wire flat to the board but you have to be careful doing that because its precision work, good luck. . .
Old Jul 27, 2003 | 04:58 PM
pinoybboy's Avatar
pinoybboy
yeaah...T_T situation kinda blows....it's not THAT big of a problem, considering i RARELY ever use the fan for my feet.....(that's the light that doesn't light up, and the windhshield defogger + feet fan). But STILL! ahhhhh poo...still working at it though, i'm sure it's possible...or at least i hope it is. hahhaa....and here are some pictures..
that's a correctly soldered led
that's a horribly done p.o.s. soldered led
and...i'm attempting to solder a wire to the surface....i THINK i can handle some pretty precise work...considering i used 0607 sized surface mount resisitors (they're DAMN small...hahah but it still worked! =^_^=)
Old Jul 27, 2003 | 09:27 PM
accordfreak's Avatar
accordfreak
switch it around.
Old Jul 27, 2003 | 09:34 PM
pinoybboy's Avatar
pinoybboy
Switch it around?
Old Jul 27, 2003 | 09:35 PM
accordfreak
the positive and negative
Old Jul 27, 2003 | 11:11 PM
DIYguy's Avatar
DIYguy
NWH's DIYguy
if you mean, you scraped off were the led's solder connects to the board...follow the circuit board to the nearest connection point, and solder a connecting wire
