Help with suspension technique rear sway bar install
Hi. Anyone have pics or a how to for a 5th gen rear S/T sway bar install? Any help would be appreciated thanks. I tried the search and nothing came up.
Did you have to drill holes? Or was it a simple bolt on. Cuz, I have an LX and it doen't come with a stock rear sway bar? If I have to drill holes, where do I drill them? Thanks!
there will be a hole in the trailing arm already. i have an ex so there was the stud that held the original bar in the hole that had to be taken out, i'm not sure if yours has a stud in it or if it is just the hole, either way, i'm sure you don't have to drill.
ok here's the pictures, i was too lazy to take off the wheel so make what you can of the outside picture. at least you should be able to tell the whereabout of the hole from these.
