Air Intakes?
Old Jul 20, 2003 | 12:37 PM
eternal's Avatar
eternal
00AccordCoupe
Default Air Intakes?
Newbie question for you. Any suggestions on air intakes for a 2000 Accord Coupe? Also - will the ecu automatically adjust settings for the new intake or will I need to make manual adjustments?
Old Jul 20, 2003 | 01:10 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
yes there are intakes for ur car and yes ur ecu will adapt automatically.
Old Jul 20, 2003 | 01:26 PM
intakes are intakes, ebay or brand name. the main differances are:
the bracket and support system. an AEM CAI has 2 brackets, an ebay one just hangs off of throtle body
AEM and Iceman are the only 2 CARB exempt intakes. if you live in CA, you won't pass your inspection otherwise
you can reset your ECU after installation by removing a fuse, i'll give you instructions if you need them
also, the 6th gen intakes are not body specific, coupe or sedan, it's all the same. the V6 and I4 intakes differ though.
Old Jul 20, 2003 | 06:49 PM
jasonkseaman's Avatar
jasonkseaman
Go With AEM. Don't cheap out on other brands when it comes to hondas...AEM will smoke the rest of them out...besides, if you know where to look, you can get an AEM for almost as cheap. Try www.coximport.com. I got my CAI from there for $164. And it was worth it.
~Jason
Old Jul 20, 2003 | 06:50 PM
Sure-Oz's Avatar
Sure-Oz
Yeah I love my AEM CAI!
Old Jul 22, 2003 | 08:41 AM
eternal's Avatar
eternal
00AccordCoupe
Thanks for the advice guys!
Hey Eklypse39, could you post the instructions for resetting the ecu? Many thanks!
Old Jul 22, 2003 | 09:14 AM
The correct way to reset the ECU is:
- open the passenger door
- on the SIDE of the dash is a little door
- pull the door off
- on the back of the door, there is a diagram
- locate (on the diagram) the #13 fuse "CLOCK/BACK UP"
- Now locate the 7.5 amp (MAROON) fuse on the fuse panel
- pull the fuse out
- wait 2 minutes
- re-install fuse
- reinstall door
- drive car "normal" for 15 minutes
credit goes to Ei-Accord for this one
don't listen to anyone who tells you otherwise.
_____________________________
the other "method" of resetting the ECU goes like this:
disconnect the battery for 5 min
then reconnect and start the car
let the car idle for 10 min
the end
THIS DOES NOT WORK.
Old Jul 22, 2003 | 09:18 AM
eternal's Avatar
eternal
00AccordCoupe
Thanks very much for that Eklypse39. Now I need to price and track down intakes - the AEM one looks a possibility at the moment.
Old Jul 22, 2003 | 09:20 AM
use the mod search banner at the bottom of this post ... it rips through alot of vendors ... also check out www.groupbuycenter.com . you'll find the best prices there.
i got my intake though www.importhorizon.com
