Howto remove axle nut???
Old Jul 6, 2003 | 07:12 PM
frank2sy's Avatar
frank2sy
Default Howto remove axle nut???
Hi, I'm trying to change the front rotors for my 97 Accord SE. I've already disassembled the calipers and the caliper holders, but I just can unscrew the front axle nuts. There are dents on both of the nuts, and I think they are there to keep the nuts from unscrewing themselves. Do I need special tool to pound the dents back out? or can I just use a flat head screw driver? I got the 36mm socket already, do I need anything else? Please help!
Old Jul 6, 2003 | 08:21 PM
TypeSH's Avatar
TypeSH
undent them, I used a variety of things like screwdrivers to pound the dent out.
I ended up needing a 3/4" drive breaker bar and a 5ft pipe to break the thing loose. Just hope your's isnt rusted on or something.
Old Jul 6, 2003 | 10:39 PM
aero3685's Avatar
aero3685
Yeah, you will have to get a big breaker bar, I got an 18 inch one, and then also used a long metal pipe on the end of that. I had to also stand and jumped on it before it finally broke loose.
Old Jul 6, 2003 | 10:47 PM
slpycd7's Avatar
slpycd7
H22 fo lyfe!
Leverage is key.
Old Jul 7, 2003 | 12:00 AM
whoaitslen2's Avatar
whoaitslen2
hermit
Watch out, its tightened to 180ft lbs if i remember correctly. I unbolted mine with a 4ft pipe on the end of a friend's breaker bar. I broke my breaker bar stomping on it . I also had a friend stomp on the brakes so it wouldnt spin. Good luck.
*edit* also sprayed the nut with wd40 30 minutes beforehand
Old Jul 7, 2003 | 12:15 AM
TypeSH's Avatar
TypeSH
btw, break it loose before you jack the car up when the car is on the ground. The tires will prevent the thing from turning.
Use a 3/4" drive breaker bar if you can, i too broke my 1/2" drive one on the axle nut. 5ft pipes are your friend
Old Jul 7, 2003 | 04:44 AM
pdr's Avatar
pdr
ridiculously good looking
I used a 5ft torque wrench on my SE-R. It came off quite easily.
Old Jul 7, 2003 | 05:58 AM
frank2sy's Avatar
frank2sy
Thanks for the help guys. I will try it probably tomorrow. Thanks!!!
Old Jul 7, 2003 | 12:41 PM
frank2sy's Avatar
frank2sy
Also, do you turn the axle nut counter-clockwise to remove it for both the driver and passenger side?
Old Jul 7, 2003 | 02:24 PM
TypeSH's Avatar
TypeSH
Righty-tighty , Lefty-Loosy
easy way to remember which way to turn it, so left or counter-clockwise is loosen, same counter-clockwise for both sides.
and where the hell can u get a 5ft torque wrench?????
