Brake problem in 4g
Old Jul 3, 2003 | 02:06 PM
hype8912's Avatar
hype8912
Dr. Klaw
Default Brake problem in 4g
I had to slam on my brakes a few days ago to miss some tourist who pulled out in front of me at like 50 and the ABS sure don't work anymore - but thats a different story. Well after this my brake pedal is really mushy when it comes to using it softly like in traffic. I have pretty new brake pads. They still have at least an 1/2 inch on them. The brake fluid looked pretty black like oil so I figured a good brake system flush would do the trick. I bought a one man bleeder thing at Advanced auto with a few bottles of 5.1 fluid. Did the whole system flush yesterday. Well today driving home from work in traffic the pedal went all the way to the floor when I press it very slowly, but if a hit it hard the brakes work like their supposed to. I figure its the Master Cylinder, but I wanted to get a few more opinions first. I also checked the vacuum check valve and it is working fine.
Anybody else have any ideas?
Old Jul 4, 2003 | 05:23 PM
usc's Avatar
usc
either you master cylinder is going bad, or somewhere, there's a leak.
Old Jul 4, 2003 | 10:01 PM
hype8912's Avatar
hype8912
Dr. Klaw
I don't think there is a leak because the fluid level stays the same even over a few days of time.
Old Jul 5, 2003 | 05:12 PM
KMFDM's Avatar
KMFDM
could you have gotten air in the lines?
Old Jul 5, 2003 | 10:22 PM
hype8912's Avatar
hype8912
Dr. Klaw
No because I did the flush and bleed after the problem. I did the bleed good. No air bubbles were in the clear tube.
Old Jul 5, 2003 | 11:11 PM
slickboy's Avatar
slickboy
ECHC junkee
I'm in the same boat as you are. My girlfriends Accord is having the same problem, it's a 91. When you sit at a light in her car, the pedal slowly sinks to the floor. I bled the brakes today, no air bubbles, and there is plenty left on the pads and rotors. I'm guessing master cylinder or brake booster is going out. There aren't any leaks so that's a good sign.
Old Jul 5, 2003 | 11:20 PM
Rawbeef's Avatar
Rawbeef
chillin
this is a little off topic but something's weird going on with my abs on my 5th gen. the light on the abs light came on and the car's about to be sent to a shop, but after like a week or so, i dont see the abs thing light up..
is there still a problem with the brakes?
Old Jul 6, 2003 | 10:00 AM
hype8912's Avatar
hype8912
Dr. Klaw
drive down a back road at 35 and slam on the brakes. If you hear alot of screeching and see smoke roll up. Then you ABS isn't working. Pay attention to feeling a pulsing feeling went the hit the brakes hard. This is the ABS controller working. ALso pay attention to see if certain wheels aren't working.
Mine only works in the rear. Its done this since I bought it.
