Engine sounds on 03 Coupe
Old Jun 6, 2003 | 05:36 PM
jlin615's Avatar
jlin615
03.Accord.Coupe.LX
Default Engine sounds on 03 Coupe
I got a 03 Coupe LX 4-cyc. When I have the car in parked with the engine running, the sound volume of the engine sounds a little of loud. Maybe I'm just paranoid, but I thought it should be super quiet.
Old Jun 6, 2003 | 06:05 PM
whoaitslen2's Avatar
whoaitslen2
hermit
Yeah the new k-series motors are pretty loud. Ive noticed it with the rsx's and civic si's.
Old Jun 6, 2003 | 07:08 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
timing chain (k-series) vs. timing belt (on old-F and J's)
Chain = long life = noise = no replacement needed.
Belt = smooth = quite = $$ to replace every so often
Old Jun 6, 2003 | 07:18 PM
jlin615's Avatar
jlin615
03.Accord.Coupe.LX
??? no idea...
MrChad. By the way, what's your homepage for your ride? I seen it before, but like to see it again
Old Jun 6, 2003 | 07:25 PM
MrChad's Avatar
MrChad
All the new Honda 4-cylinder engines are K-series based and use a timing chain instead of belt to run the camshaft off the crank.
All the 6-cylinders and older Honda 4-cylinders use a timing belt to run the cam off the crank.
Timing chains make more noise. Honda, Nissan, etc. are all using new quiter timing chains, but they still aren't as quite as a belt. Up note--you rarely if ever need to replace a timing chain--in theory they can last forever vs. a timing-belt.
I'm currently moving my pictures to my Yahoo DSL site but I'm having issues. Until then, use this:
http://www.cardomain.com/member_page...Honda%20Accord
Old Jun 6, 2003 | 09:00 PM
F23A4_AcCoRdude's Avatar
F23A4_AcCoRdude
i think the new k series engines sound awesome. Except for that pinging, clicking noise at idle (which is normal), the engine sounds really high-tech and kinda high-pitched, which is pleasant to hear for me atleast.
Old Jun 7, 2003 | 05:59 AM
jlin615's Avatar
jlin615
03.Accord.Coupe.LX
are there additive fluids that you can add to the engine after new oil change?
