Indiglo door sills
Old Jul 4, 2002 | 08:44 PM
kevinlau's Avatar
kevinlau
Default Indiglo door sills
I just got 2 indiglo door sills for my accord ex coupe.
Has anyone installed those before? There are 2 wires, 1 to the micro switch at the door, the other is to the power. I know how to connect to the micro switch, but where do I get the power from? Also, how do I hide the wire under the carpet as I need to connect to the other door sill.
Thank you.
Old Jul 4, 2002 | 08:51 PM
Fryd_Up's Avatar
Fryd_Up
rebmeM roineS
run a power wire in from your battery or from where the battery connects to the underhood fuse box. Bring it thru one of the rubber seals on the firewall and inside.
Old Jul 4, 2002 | 09:22 PM
Accord 2NR's Avatar
Accord 2NR
Sound kinda cool...anyone have pics of these?
Old Jul 4, 2002 | 09:41 PM
Fryd_Up's Avatar
Fryd_Up
rebmeM roineS
search ebay
Old Jul 4, 2002 | 09:59 PM
kevinlau's Avatar
kevinlau
I am new to car modding... does anyone have pictures on how to connect the wires? Much appreciated...
Old Jul 4, 2002 | 10:05 PM
Fryd_Up's Avatar
Fryd_Up
rebmeM roineS
goto radioshack and buy some Bullet Wire Connects
also have a Good pair or wire strippers handy to crip them connecters.
heres how the power wire on my neons is wired up and where it goes thru the firwall at.
wheres its attached is where the power from the battery hook to the fuse box. its held down by a screw. I unscrewed the screw, attached a loophole type connecter to the wire and then put it under the screw when i tighten it, or you could just wrap the wire aorund the screw when you put it back in. And dont forget to install an Inline fuse holder at most 1 foot away from where the power source is.
Old Jul 6, 2002 | 07:06 AM
NuceMan's Avatar
NuceMan
Here you go, I already have them installed for some time now.
Old Jul 6, 2002 | 11:16 AM
crucial Si's Avatar
crucial Si
Banned
why dont you connect it to the switch to were the door opens it turns on and when you shut the door it will shut off?
Old Jul 6, 2002 | 11:19 AM
NuceMan's Avatar
NuceMan
I ran the power wire to the fuse on the passenger side for the door and the negative wire into the door pin. Thats the only way I could figure out to do it effectively. Door opens light turns on. Door closes light turns off......
Old Jul 8, 2002 | 08:46 AM
crucial Si's Avatar
crucial Si
Banned
yeah thats they way i would have done it.
