Brake Lights - Not working
Old Jul 4, 2002 | 11:54 AM
TJCCARDCO's Avatar
TJCCARDCO
Default Brake Lights - Not working
My brake lights are not working for ****. I don't know what the problem is. I did a auto to manual swap.
Don't exactly know whats going on..
Old Jul 4, 2002 | 04:11 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
did you blow out your bulbs perhaps?
reverse lights not working i could see happening.
not brakes though... got nothing to do with the tranny.
Project EVA - The Track Package
Project EVA
Old Jul 4, 2002 | 04:12 PM
AcuraFanatic's Avatar
AcuraFanatic
Could be a fuse too, especially if you were working in that general area.
Old Jul 4, 2002 | 07:31 PM
TJCCARDCO's Avatar
TJCCARDCO
see the weird thing is, the bulbs work when I have my lights on so the brake light bulbs can't be blown. Plus they don't look blown. Everything is plugged in, it's not an easy fix or so it looks like.
The fuses are all in correct. Because there is a fuse for the Brake lights and the horn it's the same one, it's a 20 fuse, and it isn't blown The horn works.
Old Jul 5, 2002 | 05:56 AM
bonestock's Avatar
bonestock
u check both the fuses under the hood and under the the steering column
Old Jul 5, 2002 | 10:59 AM
senojscott's Avatar
senojscott
Type S & Accord
Why don't you use a volt meter and check the power right before the bulb. That's a start to eliminate some possible issues. Then check the power on the fuse and see if you have power there. If you have nothing at the lights but at the fuses then you have a issues between them. Which will be tough from there. But if you have power before the lights then it's the bulb or harness. Just my 2 cents.
Mr.Tao
Accord
Sep 22, 2004 07:02 AM
nyc1jxf
Legend, RL, & RLX
Aug 25, 2004 04:56 PM
adrock
2
Aug 15, 2004 06:22 PM
Mac O
92+ Civic/EL & Del Sol
2
Jun 4, 2004 10:09 AM
KiKi
Jan 22, 2004 11:15 AM
