squeeling brakes - help
Old Jun 2, 2003 | 06:59 PM
AccordManiac's Avatar
AccordManiac
Korean Member
Originally posted by Illicit Accord
one thing you gotta know about hondas, if you don't get OEM that shits gonna squeek like hell, trust me. i just replaced my breaks with OEM breaks from Honda, one of my buddies works there so i got them for cheap " $37." i got the pads the metal plates and the OEM grease anti-squeek stuff, works like a charm. Plus it's a lot cheaper than buying some crappy schuks brand. One of my buddies spent like 90 on breaks from schucks then another 30 on anti-squeek stuff. and his breaks still squek like hell. If you don't know someone who works at Honda, perhaps i can see if i can send you some... that is if you wanted....
peace
:thumbup:
Old Jun 3, 2003 | 12:12 PM
KMFDM's Avatar
KMFDM
alright i went to honda and got some pads. one question, they came with the metal shims that go on the back of the pads and the grease. do you put grease in between the shim and the pad, or just on the back of the pad ? thanks.
Old Jun 3, 2003 | 01:34 PM
Illicit Accord's Avatar
Illicit Accord
ok heres what you do, after taking out the old pads, you take the new pad and put the shim on it, then you take some of the grase stuff and put a light coat, so you can have enough for 4, everwhere on the pad except the acctuall pad part that touchs the rotor. make sure you get the grease along the sides that is the most important part. and DO NOT rush through this, take your time make sure you get everything greased up before you put the pads in, it took me about 45-60 mins to do a good job, make sure you take it easy. i hope that helps. if you got any more questions gimme a holla
Old Jun 3, 2003 | 02:56 PM
KMFDM's Avatar
KMFDM
by on the side, do you mean the edges of the metal part, or the actual side of the pad?
Old Jun 3, 2003 | 04:59 PM
Illicit Accord
yea the edges of the metal part, like i said, everywhere on the pad except for the pad its self " the part that touches the rotor," so yea just on the metal part :thumbup:
Old Jun 3, 2003 | 05:14 PM
skabone69's Avatar
skabone69
Do you guys know how much OEM rotors go for? I'm thinking I'm going to have to get some new rotors, and I saw Brembo blanks for about $40.
