brake lamp
Old May 29, 2003 | 09:50 AM
93accord4door's Avatar
93accord4door
upgraded to 97 ;]
Default brake lamp
recently i was drving my car, and the brake lamp light came on, but as far as i can see my brake lights some on, im not sure if all of them are on, but if not, how could i fix this? this brake lamp is very annoying
Old May 29, 2003 | 10:29 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
its gotta be a bulb out... have someone hit the brakes and you watch to see which one it is... replace the bulb and you'll be all set.
Old May 29, 2003 | 10:31 AM
Josher's Avatar
Josher
I'm assuming that by brake lamp, you mean the light on your dash saying "Brake". This lights up when you have your e-brake pulled or if your brake fluid resevoir cap comes undone - (least that's what happens on my Integra). Check these two potential problem sources first, then post back.
Old May 29, 2003 | 10:44 AM
93accord4door
upgraded to 97 ;]
ok change the bulb, thanx!
Old May 29, 2003 | 12:11 PM
DJ Scotty's Avatar
DJ Scotty
My light on my 99 EX V-6's dash just came on too; it says BRAKE LAMP...my girlfriend went out to the back and watched as I stepped on the brake, and she said one of those square inner brake lights on the coupe (under the triangular corner pieces) was out; its not very obvious....will a gas station or ordinary place fix this for me?
Old May 30, 2003 | 04:20 AM
Josher's Avatar
Josher
I think some ordinary places will, but its usually not that difficult to change the bulb yourself. Odds are, you'll be replacing the other side one day too, so it won't hurt to learn how to do it yourself. There's always the dealership, but that'll cost you....
Old May 30, 2003 | 05:12 AM
H-Accord-22's Avatar
H-Accord-22
Duh
:slap:
On the scale from 1 - 10(hardest), it's probably 0.5 of changing the bulbs. Check you owner manual for instruction or take a peek at those Haynes manual while stop by your local autozone or pepboys.
Old May 30, 2003 | 05:17 AM
OffDuty's Avatar
OffDuty
double check the third brake light too.. can be tricky or easy to overlook of the 3.
