Wheel question
Old May 20, 2003 | 10:38 PM
crackmatic99's Avatar
crackmatic99
Default Wheel question
I drive a 99 LX sedan, and am getting 17's soon. Not trying to spend a huge amount of money, since my cars paint job is magnetically attracted to shopping carts and pickup doors, but i found a company called 'RS Racing' that makes a konig tantrum copy called the RS 123. just wondering if anyone has any experience with them or know if they are a reliable company. also, has anyone had a 205/40/17 tire on their accord? ---thanks
Old May 20, 2003 | 10:42 PM
never heard a thing about the RS quality, but be sure to have your drop prepared. 17's will make any accord look like an SUV.
Old May 20, 2003 | 10:44 PM
crackmatic99
tru---also, if ya'll want to see them, the rs 123's are at this link: http://www.speedandstyle.com/index_main.htm
Old May 20, 2003 | 11:15 PM
crackmatic99
will i need to change anything for my speedometer, since i am switching from 195/60/15 to 205/40/17 ?
Old May 21, 2003 | 07:01 AM
Funkwheat's Avatar
Funkwheat
Haha, that's kind of a good question, I always wondered that myself. I'm pretty sure you don't, but it almost sounds like you would... I'm not sure how a spedometer exactly works, though.
Old May 21, 2003 | 09:49 AM
LowAccord's Avatar
LowAccord
The difference should be minimal so I wouldn't worry about it. You can always guesstimate by placing the your stock wheel and tire next to your new rims and tire and see if there is to much of a height difference between them. Also, any decent shop will tell you if you need to adjust you odometer when you get the new rims.
Here is a handy cut and pasted guide from www.whalentire.com
STOCK TIRE SIZE: 195/65R15
Recommended Plus Sizes
PLUS 0 SIZE(S)
195/65R15 Same diameter as stock
185/65R15 0.51 Inches shorter than stock tire
PLUS 1 SIZE(S)
Require 16 inch wheels
205/55R16 0.10 Inches shorter than stock tire
225/50R16 0.12 Inches shorter than stock tire
215/50R16 0.52 Inches shorter than stock tire
PLUS 2 SIZE(S)
Require 17 inch wheels
225/45R17 0.01 Inches shorter than stock tire
215/45R17 0.36 Inches shorter than stock tire
215/50R17 0.48 Inches taller than stock tire
PLUS 3 SIZE(S)
Require 18 inch wheels
225/40R18 0.11 Inches taller than stock tire
215/40R18 0.21 Inches shorter than stock tire
*Note the the stock tire size for a 99 Accord LX is 195/65/R15
As you can see, the differences are very small. Shorter means that the speedo will run a but faster than you are actually going, but not by much, and vice versa. I went from 195/65/R15 to 225/45/R17, they are exactly the same overall diameter and I didn't change my speedo.
Hope that helps.
