Changing brake pads and rotors question
Old Apr 29, 2003 | 01:01 PM
chuanger's Avatar
chuanger
Default Changing brake pads and rotors question
I'm going to be swapping out my front oem rotors and pads only on my 96 accord and was wondering if I needed an impact screw driver?
I'm going to replace them with brembo blanks and axxis metal master pads for any who are interested. Thanks.
Kenji
Old Apr 29, 2003 | 02:11 PM
groovedaddy's Avatar
groovedaddy
Probably. Check out: http://www.hondatuningmagazine.com/t...ht_rsxbrakes/\
Very detailed descrip of changing rotors/pads.
Old Apr 30, 2003 | 11:56 AM
TypeSH's Avatar
TypeSH
nope you dont.
the front rotors are held on by 4 bolts thru the hub. Kind of a pain in the ass though to switch.
Old Apr 30, 2003 | 02:33 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
You can always get around the impact issue by removing wheels with car on stands. Before you tear apart your brakes get a friend to sit in the car and apply the brakes. Then you can use a screwdriver and vise-grips for leverage to remove any impact screws holding rotors in place. Worked great for me.
