ABS help needed
Old Apr 15, 2003 | 07:43 PM
muff diver's Avatar
muff diver
MUFF DIVER
Default ABS help needed
on a 1996 EX 4 cyl accord with 120K miles
sometimes when car is started, abs light stays on, and continues to stay on while driving
turn off car, restart, light goes away
any ideas what it is?>
Old Apr 15, 2003 | 07:59 PM
aux's Avatar
aux
More Black on Black Crime
when u start the car do you hear a buzzing sound?
Old Apr 15, 2003 | 09:23 PM
muff diver's Avatar
muff diver
MUFF DIVER
yes
Old Apr 16, 2003 | 06:11 AM
BustedLX's Avatar
BustedLX
Rice Rocket
Check your ABS Fluid Level. Also if you drive with the regular brake light on if you where low on fluid or like as if you had the parking brake on and didn't release it all the way so it just kept the Brake light on it will trigger a trouble code in the ABS system.
Old Apr 16, 2003 | 07:07 AM
muff diver's Avatar
muff diver
MUFF DIVER
thanks guys, i'll check it tomorrow
btw is there a way to clear the code?
Old Apr 16, 2003 | 07:25 AM
H-Accord-22's Avatar
H-Accord-22
Duh
I also have the same problem, i check the fluid level, it still high, is there any1 know how to check the codes?
Old Apr 16, 2003 | 10:54 AM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
yeah pull your Postive Battery wire for 10-15 mins and plug it in again & start ur car and let it sit there for a few mins.
