HELP!!! front stud replacement
Is this job as easy as the rear? The 3rd step says draining the drive axle fluid. Please don't say "get a haynes" because I already have one.
Thanks, Spy
Thanks, Spy
Ok, now I have to rephrase my question:
How do you remove a counter-sunk 14mm bolt that you've stripped(see red arrow) because you're too hard headed to get a mechanic?
Actually, I wish I knew a good mechanic I could trust.
The wet stuff is liquid wrench.
