93 accord abs sytem problems
Old Jun 20, 2010 | 10:00 PM
rain0326's Avatar
rain0326
Default 93 accord abs sytem problems
hi evry one ,, i have a 93 accord had it over 9 years ,am gaving probems with my brakes , i changed the brake mater cylinder,and the front passenger side and the back driver side caliper have no presure, so i went to the abs sytem and tes each line with 30 to 40 pounds of presure, all worked but when but back toghter at the abs the same two dont have presure ,,, any ideas,,,
Old Jun 21, 2010 | 04:36 AM
DOZ5's Avatar
DOZ5
It could be that the Modulator is clogged. From your test it definitly seems that way. Normally when the ABS is at rest meaning you are not slipping, the ports should be opened and let the fluid flow through.
Cleaning the ABS could be very difficult task. It is a complex unit.
You can get a unit on ebay for around $100 or so, but the seller must guarentee that the unit is in working condition. I replaced mine and it works great now for two years. It eneded up not being the issue but I did not swap back. And it was not on a 93 accord but on 99 accord V6.
