Timing Belt replacement questions
Old Mar 26, 2010 | 06:15 AM
tonyEazy's Avatar
tonyEazy
Default Timing Belt replacement questions
I am looking to do my first major mechanic job, a timing belt, timing balancer belt and tensioner on my own car 1997 Honda Accord LX, has 198K miles. I found a how to video, but it is for a Accord VTEC. So my question is this, would I change it the same way as the one the video when it comes to replacing the following, or are they totally different? The only thing i would do different is not us a torch to remove the crankshaft pully, i would use a Powerbuild 648796 Honda crankcase pulley removal tool instead.
Thanks.
Old Mar 29, 2010 | 06:47 AM
tonyEazy's Avatar
tonyEazy
Has anyone replaced a timing belt on a 1997 Honda accord?
Old Mar 29, 2010 | 06:52 AM
Line7's Avatar
Line7
Platinum Member
Anytime you do a job like that you need a manual on hand. Although I have done the timing belt/engine swaps before I would not do it without a manual. I cant answer your question because I have never worked on an Accord, but I can bet that timing belt proceedure is the same for Vtec/non-Vtec models.
Old Mar 30, 2010 | 06:26 AM
tonyEazy's Avatar
tonyEazy
Line7 thanks for the reply.
Old Jul 4, 2010 | 10:27 AM
oilhead110's Avatar
oilhead110
Don't use the torch, it's unnecessary, don't use an impact wrench, buy the crank pully holding tool. Replace the water pump when you do the belts. Don't rely onu-tube videos, that guy is a slob mechanic.
YouTube- how to change timing belt in a Vtec honda accord
Thanks.
Old Jul 11, 2010 | 03:00 PM
SamVVT's Avatar
SamVVT
Here is another DIY but it's a Civic. It doesn't have the balancer belt but gives you another perspective. You have to have a repair manual Hayes, Chilton, Autozone free guide, or OEM. Get one and follow the directions to the letter.
http://www.hondatuningmagazine.com/t...elt/index.html
Absolutely change the water pump. I'd do the oil seals as well. I think the I4 turns counterclockwise?? So you'd need a torque wrench that can torque left hand.
Thanks.
