car running really hot and idleing high?
Old Mar 23, 2003 | 11:32 AM
accordfreak93's Avatar
accordfreak93
good as new, well almost
Default car running really hot and idleing high?
hey guys, the other day, i noticed my car was running really hot and idleing kinda high. the temp guage is actin wierd, its not stayin at one temp for very long. sometimes its at the red line and then drops down. also, the car has been idlein higher than normal. usually its at like 700 rpms but now at like 11 or 1200. really wanna figure this out before somethin happens. thanks.
Old Mar 23, 2003 | 12:00 PM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
check everything from your temp sensor to coolant. Your car should never run close to red. Take it too someone before your blows.
Old Mar 23, 2003 | 12:03 PM
bambbrose's Avatar
bambbrose
you might just be low on coolant. you checked that yet?? because sometimes that will result in a jumpy temp. gauge.
Hope you figure it out.
Old Mar 23, 2003 | 12:09 PM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
1) check coolant
2) might be thermostat
3) check hoses
4) flush cooling system and check radiator for cracks
Old Mar 23, 2003 | 01:15 PM
AccordManiac's Avatar
AccordManiac
Korean Member
Your problem could be cause by many different things..
So replace the cheapest things you can think of..
One of the member had over heating problem and
it was radiator cap... Good luck!
Old Mar 28, 2003 | 12:50 PM
accordfreak93
yeah i been noticing a little bit of coolant leakin out the top of the radiator, guess ill check that first. thanks for the input.
Old Aug 24, 2008 | 04:48 PM
vincemasi's Avatar
vincemasi
could it be your inition timing? im havng the same problem
Old Aug 24, 2008 | 05:17 PM
Misa's Avatar
Misa
Pic Whore
hey.... its been 5 years.... i doubt he still has that problem.... or the same car
