How to Keep Dust away when doing Garage painting?
Old Mar 25, 2003 | 11:18 AM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
Stick a big exhaust fan in the nearest window :dunno:
Old Mar 25, 2003 | 05:52 PM
boydrifter's Avatar
boydrifter
what is wet sanding?
Old Mar 26, 2003 | 04:34 PM
Accord97's Avatar
Accord97
how many clear coats are used??
Old Mar 26, 2003 | 05:19 PM
vtecinside's Avatar
vtecinside
Cracker Quack!
Simply, wet sanding is using a ridiculously fine grit sand paper and using water between the surface and the paper.
You use it for a final sanding, the ultimate finishing touch, minor surface blemishes that prolly should just be ignored, but aren't cuz youre a psycho perfectionist.
hope that helps a little...
btw if you have to ask: DO NOT TRY THIS AT HOME!
noel
Old Mar 26, 2003 | 07:52 PM
H-Accord-22's Avatar
H-Accord-22
Duh
accord 97 - normally 3 clear coats are needed
Old Jul 5, 2003 | 02:12 AM
green2dr's Avatar
green2dr
you wet the ground and walls with water to keep the dust from flying up
