alignment problems
Old Mar 22, 2003 | 12:54 PM
Blown383's Avatar
Blown383
Default alignment problems
I'm having problems with getting the car aligned. Generally speaking I know that the toe settings can only be set back to zero however it seems that the alignment guy can only get 3 wheels aligned properly. The rear passenger side shows a reading of -3 caster. He couldn't see to see any place to adjust caster on the rear of the car...so he attributed the -3 degrees of caster to leaking shocks. Does that make any sense?
Btw the car is a 97' EX V-6 with 100K on the clock and completely stock!
-B
Old Mar 22, 2003 | 08:12 PM
cwa107's Avatar
cwa107
Alignment techs are not always SAE-certified mechanics. Personally, I'd get a second opinion.
Old Mar 25, 2003 | 08:01 AM
JimBlake's Avatar
JimBlake
Default Re: alignment problems
Originally posted by Blown383
... He couldn't see to see any place to adjust caster on the rear of the car...so he attributed the -3 degrees of caster to leaking shocks. Does that make any sense?
No. Caster only makes sense for the steering. You mean camber?
Besides, leaking shocks are bad, but they don't have anything to do with alignment angles. Look for bent parts. Better yet, look for a better mechanic...
Old Mar 25, 2003 | 03:54 PM
mickey513's Avatar
mickey513
LOOK FOR a different mechanic.
