93 Lx starting issues
I replaced my starter back in september, my battery is pretty recent, about may of '09, and alternator and distributor are both pretty recent too.
But recently with in the past 2 weeks I have had a very hard time getting my car to fire up. When I turn the key, it will turn over like normal, but the longer I hold the key/the more times I try, the engine crank is slower and slower until it wont turn at all. And then when I get jumped off from another car, I only have to be hooked up to the other car for less than a minute and it will fire up like it was a brand new car.
I dont know what all it could be
or if there is a way that I can check to see if Im grounding out somewhere and loosing a little power.
The fact that you shouldn't hold the key and let your car crank and crank aside for a minute, perhaps your alternator isn't making the power like it should. I haven't purchased one in a while but I guess you can still get them remanufactured. Those are notorious for not lasting long. It takes a lot of amps to crank the engine in a car and if your starter is good, your batt sounds like its not up to the job, which could be the batt or the alternator that keeps it charged.
Also inspect the large cables that run off of your battery terminals and down to the starter, plus the large negative ground cable that mounts to the battery and car. Those cables wear out over time and can cause some weird issues with starting. Prior to trying to start the car does your radio, wipers, blower, etc. work fine?
Avoid wearing out your starter cranking and cranking. If no sign of combustion when you turn it over a few times then there could be other issues, too. If it is a bitter cold weather issue, I would suspect the Ignitor, sometimes called Ignition Module. I had a cold weather starting problem for two Winters until I finally figured out what was going on. Replaced distributor (cheaper than replacing ignitor) and she began starting up like new.
