97 door locks
Old Dec 31, 2009 | 12:46 PM
teepo112's Avatar
teepo112
Default 97 door locks
Hi
The 97 accord has the door locks control unit under the front passenger seat, not in the driver door like the 94-96.
When I try to lock or unlock , nothing moves, but I can hear the relay clicking that comes from the control unit. I checked the fuse --it's ok, even swapped out for another working fuse, same clicking problem.
Has anyone had this problem?
Any help is appreciated.
Thanks
Old Jan 2, 2010 | 07:46 AM
cruzalekz's Avatar
cruzalekz
tell me, does both door locks does not work or just one side? if at least one side works, then dont change a fuse or a relay or a module...
i can help you if you can provide me a wiring diagram for that circuit
Old Jan 2, 2010 | 11:51 AM
teepo112's Avatar
teepo112
I get the same problem on both driver and passenger front lock switches, none of the 4 doors lock or unlock. Unfortunately, i haven't been able to find a diagram. The only one Ive been able to find is for 94, which doesn't help much. My initial guess is that the door lock control unit went bad. Just wanted to see if any owners out there with the same problem had to replace the whole thing or did a quick fix. Thanks
Old Jan 2, 2010 | 02:46 PM
cruzalekz's Avatar
cruzalekz
im sure its something simple. coz all the door locks are not working. blown fuse or something. u could go to kragen or something and maybe take a quick picture of the wiring diagram of the power locks for your car. then post it here.
do u have a multimeter or a test light?
