REar Camber Correction
Old Mar 6, 2003 | 06:50 PM
aero3685's Avatar
aero3685
Default REar Camber Correction
I was wondering what size the bolts are that you put the washers on. its for a 91. I figured i would get one so that i can put the washers on, and then still be able to have the bolt go all the way in. Or do you know what size washers I need, about, cuz i wont have a car to run to the store while doing this.
thanks
Old Mar 7, 2003 | 04:26 PM
TypeSH's Avatar
TypeSH
M10x1.25 pitch and anything longer than 45mm. Stock is 45mm, so you should use anything longer. washers, use either 10mm washers or 3/8"
Old Mar 17, 2003 | 04:39 PM
aero3685's Avatar
aero3685
Thanks!
