Engine Oil
Old Dec 10, 2009 | 08:30 AM
tonyEazy's Avatar
tonyEazy
Default Auto-RX & Engine Oil
I have a 1997 Honda accord with 196k miles. My oil seems to be very dirty when i change my oil every 3k miles. Does this seem like engine slugde if so does anyone have any recommendations on how to get my oil cleaner? maybe a oil engine flush? I've heard that you shouldn't get an engine flush. I've been doing some searching and found Auto-RX has anyone used this before? Any recommendations or help would be great, Thanks.
Old Dec 12, 2009 | 11:40 AM
cruzalekz's Avatar
cruzalekz
change your pcv valve... sludge mainly develops when oil and fuel mixes (blowby) together in the bottom end of your engine.
also a good idea to buy an aftermarket oil catch can. its not smog illegal to install one of these as well but will help prevent sludge buildup.
Old Dec 13, 2009 | 10:35 PM
Taccord6's Avatar
Taccord6
Oil is supposed to be dirty when you change it. You have a lot of miles too. Honda doesn't recommend a flush, so don't do it.
-What type of oil do you use?
-Type of oil filter?
-How much oil do you burn b/w drain/refills?
Old Dec 16, 2009 | 02:23 PM
tonyEazy's Avatar
tonyEazy
I use Valvoline 5w-30, filter i guess what ever is on sale, usual Fram filter. At my last oil change i went with the Fram Tough Guard filter. I don't burn any oil at least not that i notice.
Old Dec 19, 2009 | 07:56 AM
cruzalekz's Avatar
cruzalekz
change your pcv.
Old Dec 19, 2009 | 09:29 AM
trinket's Avatar
trinket
I'll probably get slapped by the pure Honda product people, but I keep four Accords on the road and all have received auto-rx treatments in the engine and the transmissions. No issues on using it on Hondas. Educate yourself on it at www.bobistheoilguy.com.
Old Dec 31, 2009 | 09:48 PM
adwardzen's Avatar
adwardzen
Probably i have did that
Old Jan 2, 2010 | 01:01 AM
timothy1238's Avatar
timothy1238
Use the best synthetic oils in the market. Make sure you replace the engine oil at regular intervals as specified by the manufacturer
____________________
Limo Hire
