Help! PW DL and Pass PW out!
Old Mar 1, 2003 | 09:33 AM
Mikes1998Accord's Avatar
Mikes1998Accord
Default Help! PW DL and Pass PW out!
Well, thought my Accord blew a fuse but the fuse is fine. The power door locks don't work at all (either using the drivers or pass door switch). Also, the passenger windows don't work when you use the driver's door switches. Every window works from their respective door switch and the drivers switch will work both front and rear drivers side windows, but not the passenger side. Any ideas? Thanks!
Old Mar 3, 2003 | 04:39 AM
Mikes1998Accord
BTT
Old Mar 3, 2003 | 05:46 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
There's a switch on the drivers door that disable's each door maybe some how it reversed the process :eh:
Old Apr 22, 2003 | 03:16 PM
Mikes1998Accord
Got a few questions via e-mail and I thought I'd post what happened for those of you who are searching.
The problem with my Accord that caused the PW/PDL failure was that the multiplex system went into shut down mode. The dealer said it could be caused by a dead or low battery. The multiplex system had to be reprogramed for a cost of $82.00. Hope this helps.
