Cleaning Headlight Bulb?
Old Feb 25, 2003 | 06:31 AM
RaceACCORDingly's Avatar
RaceACCORDingly
You are teh suxorz
Default Cleaning Headlight Bulb?
i was doing my 9005 conversion and i needed to install three o-rings to get it to fit in snug. anyhow in the process i think i accidentally touched the bulb with my winger when moving the ring.
is it safe to clean the bulbs? ive been told that i can use a q-tip and rubbing alcohol and this will work
any suggestions?
thanks.
Old Feb 25, 2003 | 07:34 AM
jschmid's Avatar
jschmid
I would use a clean soft cloth and rubbing alchohol.
Old Feb 25, 2003 | 09:51 AM
Customlowz's Avatar
Customlowz
Speedbumps Beware
what about an alcohol pad?
Old Feb 25, 2003 | 10:03 AM
99accord's Avatar
99accord
www.poksquid.com
alcohol eats away the enamel on glass... causes it to turn hazy...
Old Feb 25, 2003 | 10:47 AM
jschmid's Avatar
jschmid
:rofl:
Now that's a new one. I thought glass was made of glass, not enamel.
Alcohol, Acetone and other organic compounds may cause plastics to haze (car headlights for example) but you'll be fine with using alcohol on glass.
Old Feb 25, 2003 | 11:55 AM
JDMCivic
Guest
Posts: n/a
You touched the bulb with your winger?:ugh:
Next time use a condom but this time you can clean it off with rubbing alcohol.
Old Feb 25, 2003 | 01:58 PM
AadosX's Avatar
AadosX
:rofl: i was thinking the same thing
Old Feb 25, 2003 | 04:04 PM
RY2K's Avatar
RY2K
5 speed
:rofl: :rofl:
Old Feb 25, 2003 | 07:25 PM
defajardo's Avatar
defajardo
dude just rub it off w/ a clean cloth
Old Feb 25, 2003 | 08:04 PM
dantastic's Avatar
dantastic
cx power!
naw u gotta use rubbing alcohol to get the finger grease off
