Turn signal LED wiring - help?
I just installed a new pair of M3 mirrors on my 98 Accord EX. It was too damn cold to do the wiring for the LED turn signals. I basically know what I am doing, and trying to find out some more info first. I was wondering if anyone knew anything about doing it, and splicing the wires correctly, so I don't screw anything up.
Originally posted by snowmansur
I just bought a pair of M3 mirrors for my 98 Accord Coupe LX. How do you install these damn things? Thanks
get yourself one of those little probe things from an auto part store. it's got a needle on one side and a cable on the other.
hook the wire to a ground, and turn your blinker on. probe the wires under the dash (under the steering wheel) and probe for the wire that gives a pulsing signal when the left or right blinker is on and tap into them.
Here's a list of the diff wire colors... Don't see any for blinkers though so good luck..
Constant 12V+ White Passenger's Side Fuse Panel or Ignition Harness
Starter Black/White Near Heater/AC Fan Motor
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 White/Black Ignition Switch Harness (ABS Light)
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Release White/Red (+) Driver's Side Grey Molex
Trunk Pin Orange (-) Driver's Kick GREY Molex Connector
Parking Lights Red/Black Fuse Panel
Head Lamp Blue Left of Column Blue Connector
Hood Pin Yellow (-) Passenger's Side Green Connector
Factory Disarm Blue Driver's Door
Door Trigger Black/White (-) Passenger's Side Fuse Panel
Door Lock Black/Blue or Black/Red Panel Passenger's Side near Door
Door Unlock Orange (-)
Horn Wire Light Green/Blue Passenger's Side Fuse Panel
