Sticking EGR valve
Old Aug 25, 2009 | 11:22 AM
gearshift's Avatar
gearshift
Default Sticking EGR valve
1994 Accord ex 193K. I cleaned the valve 4k ago. I noticed
that the valve is sticking again.
I cleaned out the egr with carb cleaner.
What are the causes a valve to have this particular problem. After only 4K.
Thank you for your advice.
Old Aug 26, 2009 | 11:03 AM
cruzalekz's Avatar
cruzalekz
diaphragm problem... change the egr
Old Aug 27, 2009 | 05:55 AM
Confuc1ous's Avatar
Confuc1ous
http://www.cbxmanmotorcycles.com/pro...32-006&affid=4
Is this what we'd use to clean out the EGR?
Old Oct 10, 2009 | 11:24 PM
speedy888's Avatar
speedy888
You need to clean out the EGR passage in the intake maniflod.
Old Oct 27, 2009 | 09:59 PM
speedy888's Avatar
speedy888
You need to clean out the egr ports on the intake maniflod also.
Old Feb 10, 2010 | 05:58 AM
kevlarr33's Avatar
kevlarr33
Im having the same EGR problems and wanted to know how to clean out the valves and manifold? I replaced the EGR a few months back and Check Engine light came back P0401Innsufficent Flow??? How To take Apart and what to clean it with ?? Thanks gUYS!!!
Old Mar 12, 2010 | 05:13 PM
96 EX's Avatar
96 EX
Go to the dealer and get the EGR gasket kit ... then look at your manifold, there you will find the the passage the exhaust takes into your intake ... figure out the hardware and take it apart. BE DANG CAREFUL, not to let the carbon chunnks to go into the cylinders (assuming you take the injectors out like most apps) ... I used a scribe and a drill bit (minus the drill) to manually clean out the port holes, and sucked the carbon away with a shop vac.
