Check Engine light indicator on - need help
Old Jun 20, 2002 | 07:54 PM
aqttran's Avatar
aqttran
Default Check Engine light indicator on - need help
The Check Engine light indicator in my 99 Honda Accord came on about 3 weeks ago and it never went off. Any suggestions why or what may cause the Check Engine light to come on???
Old Jun 21, 2002 | 01:18 AM
dantastic's Avatar
dantastic
cx power!
loose gas cap?
Old Jun 21, 2002 | 06:24 AM
aqttran's Avatar
aqttran
No, I've checked that also, according to the Honda manual.
Old Sep 12, 2004 | 09:59 PM
pinesystems's Avatar
pinesystems
Default How to Turn off Check Engineer Light
Originally Posted by dantastic
loose gas cap?
If your Honda "Check Engine Light" comes on around 70,000 miles and your oil level and temperature are normal, and the car runs smoothly, try disconnecting the battery terminal and conncect it back again.
The "Check Engine Light" should turn off.
Old Sep 13, 2004 | 05:43 AM
skabone69's Avatar
skabone69
why don't you read the code with the paper clip trick, or go to autozone and have them pull the code so you can find out what is going on?
Old Sep 13, 2004 | 11:35 AM
accordvtec77's Avatar
accordvtec77
the paperclip trick doesn't work on the newer cars...the OBDII cars specifically.
Old Sep 13, 2004 | 12:00 PM
skabone69's Avatar
skabone69
yeah it does, I've done it quite a few times already. I can post the link if you want to try it yourself. jschmid has a write up over on www.honduh.com on how to pull the code for 6th gen accords. its in the 6th gen section and its listed as a sticky.
Nelson
Other Honda & Acura News
Jul 25, 2008 03:10 AM
EJ503
92+ Civic/EL & Del Sol
2
Nov 13, 2006 03:33 PM
deadi16
Do It Yourself
5
Jun 24, 2005 06:39 PM
anewsom
15
Apr 23, 2005 05:08 PM
REbornHONDAneer
Accord
9
Aug 18, 2002 04:22 PM
