HID/Xenon Projector conversion for 2003s?
Old Feb 1, 2003 | 07:11 AM
jfroumis's Avatar
jfroumis
Default HID/Xenon Projector conversion for 2003s?
Has anybody developed a HID/Xenon projector conversion kit for 2003 Accords yet? I checked out Illusion Lighting from another post, and it looks like they do clean work, but I didn't see anything for 2003 Accords yet, and I can't really send them my headlight assembly for them to do the work. What are the advantages and disadvantages (besides cost) of going with a projector assembly versus just doing the standard 9006 Halogen Bulb to Ballast + 9006 plugin Xenon bulb swap using the stock reflector housing? I'm looking for something in the 5000-6000K color range in case anybody has some recommendations on kits (listing prices and web links would be helpful). FYI, I only want to do the low beams. Thanks in advance!
Old Feb 1, 2003 | 09:03 AM
Illusion-Lighting's Avatar
Illusion-Lighting
Illusion Lighting
You can always buy a new set o lights and send those to us. Then when you get your lights, u can sell your stock ones. A lot of our clients end go going down this route
Old Feb 1, 2003 | 11:17 AM
AKUFC's Avatar
AKUFC
PANIC NOW!!!
If you do the plug in play I would paint the housing black. I did this so the light doesnt create as much glare off the chrome bottom. Everything that is needed for actual lighting wasn't painted.
I did this helped noticeably but not perfect still have hotspots.
As for kits auto-lamps are super phillip are good Hella are too McCluoh(sp is wrong ;() is pretty good too.
If you want projector I would do as see_fu has recommended
Old Feb 2, 2003 | 01:31 AM
plkalra's Avatar
plkalra
go with see_fu, his work is really clean!
do s2k projectors!
