94 Accord- Many Problems! Help!!
1994 Honda accord EX, Auto Trans
Bought the car, motor was blown.
Got SOHC VTEC from a 2000 Accord, put it in. Used 94 wiring harness, and 94 distributor. Ran fine for about a week, then stalled and wouldnt stay running.
Got it towed to the house. Checked it out. Had 2 engine codes. TPS sensor, and Fuel Injectors. Fuel injectors was the main fuel relay. I replaced it.
Installed new TPS sensor. Set reference voltage with key on. Closed throttle was .5 volts, Wide open throttle was set at 4.5V. Volts, not Ohms, mind you, by reccomendation of the TPS thread on the forum.
Now, here are the problems occuring now....
Car starts fine, idles fine, but when you put it in drive it hesitates and bucks for about 20 seconds, then it will go fine for a while, then start running like crap again.
Also, if you turn on the AC, you can't get the RMP's to go up, the car bogs down and wont go above about 750-800 idle rpm. You cannot drive the car or attempt to move it with the AC on.
I have no ECU codes now, but it still wont drive. I don't know what else to do.
I have also put in new fuel pump, and fuel filter.
Maybe the ECU is bad? Or I didn't set the TPS sensor properly?
I need to get the car on the road, gas prices are killing me!
Thanks for your help guys!
