ECU Fuse location.
Old Jan 29, 2003 | 11:02 AM
F23A4_AcCoRdude's Avatar
F23A4_AcCoRdude
Default ECU Fuse location.
Hello, i resetted my ecu a while back and i did that by just disconnecting the negative battery terminal. I was resetting it again today and i heard about pulling off the ecu fuse. I look at the fusebox under the hood and no fuse said "ECU" on it, but i found one that said "MAIN". Is the MAIN fuse the ecu fuse?? it had an amp reading of 50. Thanks.
Old Jan 29, 2003 | 11:18 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
look for the memory fuse, or radio back-up fuse... its usually that one. The main fuse is just the fuse for everything.
Old Jan 29, 2003 | 11:31 AM
F23A4_AcCoRdude
hm......where can that be found at?
Old Jan 29, 2003 | 02:53 PM
dantastic's Avatar
dantastic
cx power!
just pull the 7.5amp "back-up/radio" fuse in the box under the hood. it will reset the ecu
Old Jan 29, 2003 | 03:21 PM
F23A4_AcCoRdude
can i do this without disconnecting the battery terminal? if so, how long do i let it stay disconnected for? Thanks.
Old Jan 29, 2003 | 04:14 PM
v4lu3s's Avatar
v4lu3s
ecu is also the ecu fuse.
often when you pull the backup you lose your radio stations saved as well...
Old Jan 29, 2003 | 08:05 PM
dantastic's Avatar
dantastic
cx power!
and ull probably need your radio code if you have a stock antitheft. the ecu fuse doesnt carry any current when the car is off. you just need to pull the backup fuse for a good 30sec-min. theres no need to pull the battery cables
