ABS Codes
Old Apr 26, 2009 | 09:07 AM
jeffacura's Avatar
jeffacura
Default ABS Codes
Is there a code reader out there that can read ABS codes on a '02 Accord? Or is there a way to make the ABS light blink codes?
Old May 5, 2009 | 11:01 AM
DOZ5's Avatar
DOZ5
If you tell me what you are seeing with your ABS unit, I might be able to help you.
There is a way for resetting the light without a code scanner and yes, there is a code scanner that you can get for about $250, I forget the name of it now.
Trouble with your ABS should NEVER be taken lightly! And you should never reset the code unless you are absolutly sure why it is doing what it's doing.
Thanks
Old May 5, 2009 | 03:52 PM
jrgoswick's Avatar
jrgoswick
Some old guy!
He is WAY BEYOND RIGHT with this statement. I personally have a Snap On Solus(but it's a bit more than 250 bucks) and I love it!
Old May 6, 2009 | 08:04 AM
cruzalekz's Avatar
cruzalekz
check if the abs sensors are dirtied up sometimes you got a bad axle and the grease sticks to the sensor then the grease acuumulates road dirt then you end up with abs light on @ dash.
Old May 6, 2009 | 08:15 AM
jrgoswick's Avatar
jrgoswick
Some old guy!
Could also be the tone ring! Good call guy.
