Intake Manifold cleaning with b-12--Question
Quick question...
Does anyone know exactly what vac-hose to use when cleaning your intake manifold, with B-12 chectool?
I drive a 2005 accord V-6spd. 3.0 SOHC VTEC.
I'm assuming they are referring to the brake booster vac. hose, though I've never used that product (for that purpose). On that engine, I'm not sure if that hose feeds all the cylinders though or just one bank, I wouldn't use it if it only feeds one bank of cylinders.
If that's the case, only feeds one bank, you could try the PCV hose if that feeds into a central location on the intake manifold.
http://www.contour.org/mods/mods.php...o&displayid=43
FYI
This link is where I got the idea for cleaning my intake. My previous ride, 1998 Ford Contour SVT, had two vacuum hoses one from the brake booster and the other from IDK, that were fed to the intake, after the TB, and that did feed both banks of the motor.
As for your reply, I am not very knowledgeable on Honda motors, where is the PCV located? I have been told on the right side of the motor and towards the front, but a picture may help better.
FYI
