accord rear hub bearing, help please
i have 92 accord lx with ex rear disk brake swap, my rear hub bearing went bad, can i just change the bearing and keep the factory hub?? if yes where can i buy just the bearing? or is it better to change the whole hub assembly? and where i can buy the hub assembly?? cos i m having problem finding it online, the 1 i found is for drum brake. thank you.
http://slhondaparts.com/browse.asp?M...ViewParts=true
You can buy from there, or use the part number (42200-SM4-J51) to buy elsewhere, like here:
http://www.hondapartsnow.com/genuine...0-SM4-J51.html
I haven't done the rear bearings so I'm not familiar with the design, but looking at replacement parts from normal parts suppliers it appears that the hub is integral with the bearings so the whole piece is replaced. For $137 I would buy genuine rather than save $20 on a generic part, or pull one at a salvage yard.
