Brake Fluid Replacement...
Old Mar 15, 2009 | 05:38 PM
BigJohn817's Avatar
BigJohn817
Default Brake Fluid Replacement...
I am about to replace the brake fluid in my 1998 Honda Accord EX. I'll be using a vacuum pump. I believe it is a fairly simple process, but I'm wondering if I'm going to run into any problems with the anti-lock braking system? Any suggestion on things to look out for? Thanks.
While we're doing the brakes, can you tell me the torque values for the four bolts - two that hold the calipers and two that hold the caliper support?
