Camber Problem
Old Dec 20, 2002 | 03:00 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
Default Camber Problem
I did a search for camber fixes but all i found were fixes for the 5th gen accords using the washer and longer bolt. I have a 6 gen. and I am having Rear camber problem the driver rear is reading 0.8 and the toe is at .35 degree. I wonder if there was a cheap fix. Dont want to spend money on a Camber Kit.
Yeah yeah dont start with me about the cost of my life hehehe its X-mas and I am flat broke . Got an estimate it going to cost around $200+ to fix. can any one help
Old Dec 20, 2002 | 09:44 PM
cobbcustomz's Avatar
cobbcustomz
i dont think that the .8 camber is much of a problem at all. I think you should just get an alignment on the car and that will fix the toe and you will be fine. that's within the allowed specs i believe
-1 -- +1
Old Dec 20, 2002 | 10:53 PM
nogie's Avatar
nogie
Can't use the bolt trick with 6gens. You'll be fine with an alignment.
Old Dec 21, 2002 | 06:12 AM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
I did an alignment thats how i found out my toe is off 0.35 degrees
and the Camber is off 0.8 degrees
