95 accord press on rotor
Old Aug 17, 2008 | 04:27 PM
Tedmond's Avatar
Tedmond
Default 95 accord press on rotor
long story short, tried changing the front rotors on my accord with original pads and rotors. on the driver side, with a hub puller and 15 pound slide, it came out in 2 knocks. the pasenger side, used 20pound and it didnt even budge. used my hub remover (connects to lugs and center piece turns to pop out hub) it moved the hub alot, but still it didnt come out. Used a hammer and hit the hub from the back to tap it out and nothing. for some reason it doesnt want to pop out. any suggestions? this rotor is stubborn as hell.
Old Aug 17, 2008 | 05:13 PM
96 EX's Avatar
96 EX
Keep hitting it I guess ...
Old Aug 18, 2008 | 08:31 AM
Tedmond's Avatar
Tedmond
lol i tried. in the process, i broke my outer tie rod... the bolt just broke. oh well that needed changng anyways. now the rotor is still stuck. should i heat it up and then it might budge? maybe ill bring it to a shop?
Old Aug 18, 2008 | 05:25 PM
nspec_Cd5's Avatar
nspec_Cd5
try using some of that peneterating spray, to losen it up.
Old Aug 20, 2008 | 10:29 AM
DOZ5's Avatar
DOZ5
try using the PB-Blaster. wait an hour and try again. Autozone have it.
Old Aug 20, 2008 | 07:59 PM
A-series's Avatar
A-series
v-card member alpha
Deep Creep might also be worth a try.
Old Aug 29, 2008 | 04:44 AM
Tedmond's Avatar
Tedmond
used a whole bottle of wd40 and let it sit boys. this is some f***ed up thing. not sure why its so hard to come out? well im going to bring it to a local shop that i know to see if they can pull it off for me.
Old Aug 31, 2008 | 09:43 AM
stereo's Avatar
stereo
sounds like it's either rusted on or seized on you might be better off replacing the whole knuckle from a junk yard.
Old Sep 1, 2008 | 06:05 PM
96 EX's Avatar
96 EX
Let us know how it turns out ... I'll use your experience for future ref.
