Shift Malfunction
Old May 21, 2008 | 02:16 PM
triple5's Avatar
triple5
Default Shift Malfunction
Hi Everybody,
I have a 6th gen 02 v6 accord.
I'm keep getting this code, P0780 which is shift malfunction.
On my dashboard D4 flash, TCS and engine light comes on. I turn off engine all lights are gone except the engine light. All other gear works fine.
Do I need to replace my tranny soon???
Thanks
Old May 21, 2008 | 05:17 PM
DOZ5's Avatar
DOZ5
I had similar thing happen on my 99 accord v6.
Make sure you have the radio code first!!!
Disconnect the battery for about 5 minutes. Then reconnect. This will reset the computer and therfore the shift points will relearn.
The tranny computer get confused sometime.
Does your engine runs rough when that happens?
Old May 21, 2008 | 05:32 PM
triple5's Avatar
triple5
Thanks 4 da fast reply.
Have a aftermarket radio, not worry about the code.
Yes, it does. The engine run hotter then normal.
I always reset the light with diagnostic code reader.
