i need help doin the tv in the radio din and relocting the stero to the cig tray. and
i need help doin the tv in the radio din and relocting the stero to the cig tray. and outl let.
i know a few of you did it. so how do i do it?
You need some time , It takes a while to do , and skills with bondo are a must. Make sure that you fiberglass the screen in so that the bondo will not crack. The HU is pretty easy you just have to cut t all out and then it is a perfect DIN hole. A little tip for you , use SEM vinyl dye for you paint it is great dryes fast and does not chip because it is a dye. And for the fial coat hold the can about 12'' away and you get a good texture and it make it look like a factory panel.
Good luck.
Good luck.
i've seen 7 inch screen setups fit almost perfectly.. it all depends on the screen housing..
my 5.6inch screen fits alright.. but with a little modifications.. you just dremel out the ashtray and cig lighter part.. remember to do it little by little or else you'll make the hole too big.
kool, i was thinking of doing something similar to that, any 1 has a pic???
1 indash 7" TV Screen
1 DVD Player
1 Equalizer
1 Power Inverter
that'll take up more space
1 DVD Player
1 Equalizer
1 Power Inverter
you dont need bondo if your HU has a piece that goes over the edges.
just be patient when cutting out the bottom, it took me 1.5 hours to do it all correctly. It sucks that the TV I got didn't work though, csue I got this hole there and no TV.
anymore pics 95acc??
and whats ur audio setup?
im thinking of either getting an indash lcd or doing a project like what u did..
another question...what kinda monitor is that?
and do u have any specs of it? resolution?
looks good
looks good
