1998 Accord engine shut off
Old May 14, 2008 | 10:14 AM
lionj's Avatar
lionj
Default 1998 Accord engine shut off
Hi guys,
I have a 98 accord ex that shuts off sometimes while driving and also in park when I revv the engine it would idle low then shut off. It would start again when I turn the key. Can someone please assist? Thanx in advance.
Old May 14, 2008 | 10:22 PM
webie's Avatar
webie
My first advise will be the IACV (Idle Air Control Valve). I have a 2000 EX and had a ton of symptoms like the one you described. After trying a lot of things that one was the culprit.
You don't have to replace it right away. You can start by removing a clean it with Throttle body cleaner or seafoam. That should solve/minimize the problem for a few months or permanently.
Old May 16, 2008 | 02:43 PM
lionj's Avatar
lionj
Thanx, where is the IACV( idle air control valve)?
Old May 19, 2008 | 05:47 AM
JimBlake's Avatar
JimBlake
The IACV is #9 on the back side of the intake manifold (4-cyl). You didn't say whether you have a V-6?
Old May 19, 2008 | 05:17 PM
lionj's Avatar
lionj
Thanx Blake,
