94" accord egr problem
Old Apr 28, 2008 | 06:10 AM
blue_j's Avatar
blue_j
Default 94" accord egr problem
My cel came on with a long blink and 2 short which is 12 for the egr valve after doing some research I can clean it instean of replaing it, can someone tip me on what and how to clean it and it it has a gasket I wonder if I should replace it.
Btw 94 lx with 97 engine I'm getting like 200 miles from a full tank and it been lacking power
Old Apr 28, 2008 | 04:47 PM
Fuse's Avatar
Fuse
If I remember rite their is a plate you can take off. Its on your intake it gives you axes to the individual egr ports. I would cleaned them out and get a new gasket and egr valve. I have never cleaned an egr valve but I have cleaned out the ports.
Old Apr 28, 2008 | 07:48 PM
stereo's Avatar
stereo
code 12 is a problem with the EGR system where the valve is opening or closeing when it's not suppost too cleaning will only help if it's sticking in order to check the problem a vacuum gauge /pump is needed to check to see if theres vacuum out of the hose with the solenoid on then off if ok then check the EGR if it's moves freely and holds vacuuum then check the lift sensors .
Old Apr 28, 2008 | 09:39 PM
blue_j's Avatar
blue_j
i cleaned the ports there were dirty but the gas was still able to get by...
the light is still on....so should i replace the egr valve and the solenoid or jsut try to clean them
Old Apr 29, 2008 | 05:56 PM
Fuse's Avatar
Fuse
Up to you I have had no luck cleaning a egr valve. But It may work. Free is cheaper. Did you clear the code and re test drive? Stereo is rite you need vac to apply the egr so see if you have vac to the egr. I think you will only see vac driving so diaging it should be fun.
Old May 26, 2008 | 05:47 PM
blue_j's Avatar
blue_j
I bought a brand new egr valve and a cuple of days later code 12 again. Can I clean the other little valve there and what else do I have to look for to change
Old Jun 27, 2008 | 06:12 AM
blue_j's Avatar
blue_j
I got a new lift solenoid and a couple of days later light comes on again... I don't know what to do anymore any sugestions?
Old Jul 1, 2008 | 04:46 PM
jghall00's Avatar
jghall00
The ports are under the fuel rail. Are those the ones you cleaned?
Old Jul 5, 2008 | 09:30 AM
blue_j's Avatar
blue_j
Yeah those under the plate cleaned them and the plate also maybe im not cleaning the right thing can some one post a pic my mechainic told me im not cleaning it well it has to be cleaned throuly. To remove all the carbon build up
Old Jul 6, 2008 | 10:20 AM
PaHonda's Avatar
PaHonda
You should check the vacuum hoses that connect the solenoid/vacuum control valve to the EGR valve. Make sure that they are routed properly and in good shape (no cracks, etc).
I would also go through the diagnostic tests in the shop manual to ensure the wiring is ok. If you don't have a shop manual, http://www.dhost.info/accordinfo/ has the 94 shop manual split into chapters at the bottom of that page. You want to look at the fuel/emissions page 11-115 for EGR problems.
