'98 rear door panel removal
Old Apr 17, 2008 | 09:54 AM
rgevans's Avatar
rgevans
Default '98 rear door panel removal
The outside rear left side door handle on my 1998 Accord doesnt work. I can open the door with the inside handle. Also, if I pull hard and fast on the outside handle it will open the door sometimes. Anyone have any suggestions?
Old Apr 17, 2008 | 04:44 PM
Fuse's Avatar
Fuse
Take your door panel apart look at your outer door handle see if the rod is broken. If it is you probably need a new outer door handle thy are a pain to replace.
