97 Accord V6, Need Help!!!Having Camber Issues!!
Old Feb 23, 2008 | 09:57 PM
yodaddy4life's Avatar
yodaddy4life
Default 97 Accord V6, Need Help!!!Having Camber Issues!!
new to this site, thought i would check it out. anyone recommend a reliable,yet affordable front/rear adj camber kit for my 97 Accord v6???i just bought some new bf goodrich g-force 205 55 R15's new and my last set the inside of the front tires were all eaten up on the inside of the front tires. my suspension is completley stock. i would like to get some fancy bling wheels later, possibly some 18s. so i need some help. i live in the bay sanjose,ca and today i was quoated $450 o.t.d price ,which includes front/rear adj kit,labor and a free alignment. does anyone know if i am getting a good deal or not???? please help!!
Old Feb 24, 2008 | 09:10 AM
nspec_Cd5's Avatar
nspec_Cd5
there's something wrong w/ ur suspension. were all teh tires eaten up from inside?
Old Feb 24, 2008 | 12:31 PM
JLGotrocks's Avatar
JLGotrocks
Have you had an alignment done?Before you go spending money on something you don't need,make sure the problem is the camber,which it more than likely isn't.It's a very good chance your toe angle is off.a misaligned toe angle will wear out tires way faster than too much camber.
Old Feb 25, 2008 | 10:34 AM
yodaddy4life
yea i had the car aligned like a year ago. i was in desperate need of 4 new tires, but i could only afford to buy 2. the front needed the new tires so thats where i slapped them. the front tires i bought new were the only ones that seemed to be eaten from the inside of the tire before i replaced them yesterday. the other 2 in the back were beaten up used seemed to wear evenly after the alignment. plus i never rotated any of them at all after when i had it aligned they told me that my accord has no adjustment for camber i have the specs right here: tell me what you think from the last aligment. those guys probably did a crappy A** job
FRONT LEFT
Actual Before Specified Range
-0.6grn -0.6grn -1.0 degrees 1.0 camber
3.2grn 3.2grn 2.0 degrees 4.0 caster
0.03grn 0.02grn 0.08degrees 0.08 Toe
7.1 7.1 SAI
6.5 6.5 included angle
FRONT RIGHT
Actual Before Specified range
-0.1grn -0.1grn -1.0 1.0 Camber
3.4grn 3.4grn 2.0 degrees 4.0 Caster
-0.02grn 0.15(red) -0.08-0.08 Toe
6.5 6.4 SAE
6.4 6.4 included angle
FRONT
-0.5 -0.5 blank cross camber
-0.2 -0.2 blank cross caster
0.6 0.6 blank cross sai
0.01(grn)0.17(red) -0.16 0.16 total toe
REAR LEFT
-1.3(red) -1.3(red) -0.9 0.1 camber
0.10(green)0.39(red) 0.00 0.16 toe
REAR RIGHT
-0.6(green)-0.6(green) -0.9 0.1 camber
0.10(green) 0.08(green) 0.00 0.16 toe
REAR
-0.8 -0.8 blank cross camber
0.19(green)0.47(red) 0.00 0.32 total toe
0.00 0.15 blank thrust angle
CAN ANYONE MAKE ANY SENSE OF THIS?
